S24ultra Camera Heating issue
(Topic created on: 06-23-2024 12:01 AM)
DANNiiSH
I OPEN CAMERA THEN MY PHONE HEATING 50C HOW TO SOLVE THIS
6 Comments
Lol
Idk u opened the camera ofc it will heat u OPENED THE CAMERA lol
GalaxyNerd
It's a common sence dear if the weather temperature is hot outside and you use camera it will get more hot obviously because camera use lot of power from processor in any phone
perera93
Yes
Samsung_specialist
Based on your description, here are some common reasons why your device may be overheating:
1. Operating your device in environments outside the normal temperature range (between 32 and 95 degrees Fahrenheit).
2. Placing your device near heat sources, such as leaving it in a parked car on a hot day or exposing it to direct sunlight for extended periods.
3. Running multiple apps simultaneously, especially processor-intensive ones like gaming or streaming.
4. Using an incompatible, defective, or non-Samsung certified charger or USB cable.
5. Initial setup and data transfer from previous devices.
6. System or firmware updates.
To address the overheating issue, we recommend trying the following solutions:
1. Turn off Wi-Fi, GPS, and Bluetooth when not in use, and reduce the screen brightness.
2. Optimize your phone's settings to minimize heat caused by processor-intensive apps.
3. Limit background usage of unused apps to prevent them from consuming excess resources.
DANNiiSH
Thanks 😊
