11-08-2024 01:57 PM in
Galaxy S- Mark as New
11-08-2024 02:26 PM in
Galaxy S• Users can expect between 5-8 hours of screen-on time with moderate usage.
• The 8h 5m SOT with 65% battery usage suggests the battery lasts a reasonable amount of time, especially considering video streaming can be intensive on the battery.
• To maximize battery life, users can reduce screen brightness or switch to power-saving modes.
• Keeping an eye on updates or settings that might improve efficiency is also recommended.
11-11-2024 12:42 PM in
Galaxy SThe Galaxy S24 Ultra is known for its impressive battery life, and your 8 hours and 5 minutes of screen-on time with 65% battery usage is a good result, especially for social media and video streaming which can be power-intensive. However, it's important to note that battery life can vary depending on various factors such as:
Display settings.
Network connectivity.
Background apps.
Software updates.
To get the most out of your S24 Ultra's battery life, you can try the following tips:
Adjust display settings.
Optimize battery settings.
Manage network connectivity.
Keep software up-to-date.
By following these tips, you can further improve your S24 Ultra's battery life and enjoy longer screen-on time.
