S24 ultra new update 7 battery drain problem
(Topic created on: 05-06-2025 02:25 PM)
Sachinz
Battery helth problem
2 Comments
We’re truly sorry to hear about the inconvenience you’re experiencing, try the below steps that may assist you.
1. Clear Cache: Go to Settings > Apps > One UI Home > Storage > Clear Cache.
2. Update Software: Ensure your device is running the latest software version by going to Settings > Software Update > Download and Install.
3. Disable Unnecessary Features: Check for any unused features or widgets that may be consuming battery.
4. Force reboots your device by pressing and holding the power and volume down buttons simultaneously for more than 7 seconds and your device will reboot.
Give the phone a period after the update to adapt to the new update
