S24 ultra issues: Games keep crashing on S24ultra
(Topic created on: 02-06-2024 02:38 PM)
SymonsC
I only played one game "left to survive for samsung " on my S24 ultra, and it keeps crashing. Game was downloaded from samsung store
4 Comments
So, LISTEN TO IT AND PUT DA APP TO DEEP SLEEP YA DUMBO
Zammi
Try to uninstall and reinstall. Some of the games are not yet updated to run on S24.
Samsung_specialist
Navigate to and open Settings, and then tap Battery and device care. Tap Battery, and then tap Background usage limits. and put the app on deep sleep :
Shows you all apps that will never run in the background. They'll only work when you open them. You can add apps to the list by tapping the + sign, selecting your desired app(s), and then tapping Add. To remove apps, tap More options (the three vertical dots), and then tap Remove apps. Select the app(s) you want to delete, and then tap Remove.
SymonsC
This was useful
