02-23-2024 02:55 PM in
Galaxy S- Mark as New
02-23-2024 03:21 PM in
02-23-2024 05:22 PM in
Galaxy SIs it with everyone or only specific versions? As a lot of reviewers were able to state their battery experience for the first week, and will the performance become better after this period?
I already switched 5G off since I bought it.
02-23-2024 04:26 PM in
02-23-2024 05:22 PM (Last edited 02-23-2024 06:50 PM ) in
02-23-2024 06:29 PM in
Galaxy SHere are a few steps you can take to troubleshoot and improve battery life:
1. Optimize Settings: Review your device settings and optimize them for better battery life. This includes adjusting screen brightness, disabling unused features like location services and background app refresh, and limiting notifications.
2. Monitor Battery Usage: Check which apps or services are consuming the most battery power. You can do this by going to Settings > Battery > Battery usage. Identify any apps or processes that are draining the battery excessively and consider limiting their usage or troubleshooting them further.
3. Restart Your Device: Sometimes, a simple restart can resolve temporary software glitches that may be causing battery drain.
4. Update Software: Ensure that your device is running the latest software version available. Software updates often include optimizations and bug fixes that can improve battery life.
It's not uncommon for new devices to undergo a learning phase where they adapt to your usage patterns. During this time, battery performance may fluctuate. Give your device some time to settle in, and monitor the battery performance over the next few days to see if it improves.
Regarding the "Learning Usage Patterns" message in Device Care, this indicates that your device is analyzing your usage patterns to optimize performance and battery life. It's a normal process and should resolve on its own over time.
02-24-2024 12:34 AM in
Galaxy SCan you please tell me how long will it take for the device to learn the usage pattern?
And after that, given that I have done the steps above, will the battery be any better?
02-26-2024 02:04 PM (Last edited 02-27-2024 07:49 AM ) in
Galaxy SThe learning battery thing is finished, but it gives inaccurate information.
Kindly advise.
02-29-2024 11:42 AM in
Galaxy SIt will take some days to learn the battery usage pattern. Based on that, the device will show the battery usage after the device charging. However, if the issue persists we recommend to you to visit the nearest Samsung service center for evaluation and repair by following the link below:
