S24 ultra Google Contacts Sync Issue Causing Battery Drain After November Update
(Topic created on: 12-02-2024 11:34 AM)
Justin_Roy
After the latest November update on my S24 Ultra, I keep getting a Google Contacts sync notification every 5–10 minutes. This repeats continuously and is causing significant battery drain.
Has anyone else experienced this, and is there a solution?
10 Comments
akrammi
Nopes. At least not me.
I also updated my S24 Ultra but did not face this issue.
Can you please shutdown mobile and leave it for a while and then turn it on.
Let see if this works
Justin_Roy
Are you geting whatsapp miss call notification when your screen is lock ?
akrammi
Yes
Didionpc
Not for me either.
Didionpc
As Akrammi told you, sometimes a simple power on and off will solve the issue.
Justin_Roy
Everything dome bro
Didionpc
Then, brother, wait for the next update patch. Maybe the issue will be solved.
Samsung_specialist
We sincerely apologize for the inconvenience caused by your recent experience.
If the problem persists after trying these steps, please send us an Error Report by following the steps below:
1. Head to the Members app.
2. Select Get Help > Error Report.
3. Tap 'OK' to send System Log Data.
4. Choose the symptom and include as much detail as possible.
To ensure that your logs accurately reflect the issue you're experiencing, please submit your report within 5 minutes of encountering the problem. Our engineers will then investigate and provide you with a solution via the Members app.
Nibin
I'm having issue for a month. Got any solution for this?
