3 weeks ago (Last edited 3 weeks ago ) in
Galaxy S- Mark as New
3 weeks ago in
3 weeks ago in
3 weeks ago in
Galaxy S1 Enable Power saver
2 Enable performance mode light
3 Enable adaptive power saving instead of basic
4 Enable adaptive brightness
5 Disable AOD
6 Enable extra dim
7 Change display to natural
8 Screen time out to 30 secs (system default)
9 Record videos in FHD
10 Restrict gaming to HD or FHD and slower frame rate
11 Switch to dark mode
12 Disable near by device scanning
13 Disable WiFi scanning
14 If 5G is unavailable change network to LTE/3G/2G
15 Allow the battery to drain completely and recharge,say once a month.
16 Enable auto restart
17 Run device care
18 Disable apps running in back ground.
19 Uninstall bloat ware that came with your phone,eg. Spotify,LinkedIn etc.
You can mix match the steps above and arrive at a usage based on your needs.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
3 weeks ago in
3 weeks ago in
3 weeks ago in
3 weeks ago in
3 weeks ago in
3 weeks ago in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
