4 weeks ago in
Galaxy S- Mark as New
3 weeks ago in
Galaxy SThank you for contacting us.
While you wait for the One UI 8.5 update, you can try the following steps to improve your battery life:
Wait it out:
The phone may need time to optimize background processes after the major update. Patience is often the simplest fix. -
Wipe Cache Partition:
This clears corrupted system files that can cause post-update issues.-
Turn off your phone and connect it to a PC via USB.
Press Volume Up + Power until the Samsung logo appears to enter Recovery Mode.
Navigate to Wipe cache partition and select Yes.
Reboot the system.
Use Light Performance Profile:
Go to Settings > Battery and device care > Performance profile.
Select Light to prioritize battery life over performance.
