S24 ultra - Battery Draining
(Topic created on: 02-03-2026 03:48 PM)
Jani_
Hello,
I am having issue with S24 Ultra battery (drains quick)
Morning 6:30 charged 100%, its 3:45pm and remains 35%.
Its been 9 month since I bought phone.
Using 25watt powder adopter to charge.
Any suggestions/tips to improve battery.
5 Comments
SaMerSaFa
Yes me too .. I think the same problem 😕
A7med10Ashraf
Beginner Level 4
Me too for s 25 ultra
Eyasamer
how much screen on time?
mZoOnY
Is there any heat 🔥 ?
Samsung_specialist
Thank you for sharing the details regarding the battery performance on your Galaxy S24 Ultra.
Battery consumption can vary depending on usage patterns, screen-on time, background apps, network conditions, and device settings. After several months of use, changes in app behavior or system updates may also affect battery performance.
To help improve battery efficiency, please review the following:
  • Check battery usage details under Settings > Battery to identify any apps consuming unusually high power.
  • Ensure the device software and Google Play system updates are fully up to date.
  • Restart the device and allow a few days for the system to optimize usage if there was a recent update.
  • Enable Adaptive battery and Adaptive power saving if not already enabled.
  • Reduce background activity for apps that are not frequently used.
  • Use Device Care to optimize performance and close unnecessary background processes.
If the battery drain continues despite these steps, we recommend visiting the nearest authorized Samsung service center so our technicians can check the battery health and overall device condition.
You can locate the nearest service center using the link below:
https://www.samsung.com/ae/support/service-center/
For further assistance or follow-up, please reach us through:
https://www.samsung.com/ae/support/contact/
