05-06-2024 01:22 PM in
Galaxy S- Mark as New
05-07-2024 12:54 PM in
05-07-2024 01:21 PM in
05-13-2024 04:42 PM in
Galaxy SThank you for reaching out Efcee
Please follow the steps below;
Restrict background location: Go to Settings > Location > App permissions > Google Play Store, and set the location permission to "Allow only while using the app." This will prevent Google Play Store from using location services in the background, which can also help reduce battery drain.
Restrict background activity: Go to Settings > Apps > Google Play Store > Data usage > Background data, and toggle off background data for Google Play Store. This will prevent the app from using data in the background, which can help reduce battery drain.
