RudiFett
01-20-2026 10:58 AM in
Since the end of December, my Samsung Galaxy S24 Ultra has been displaying an error message indicating that moisture has been detected in the charging port and that the device should be charged using a charging dock. When I use my original Samsung charging cable and wall adapter (both purchased directly from the Samsung store), the phone initially starts fast charging but then stops charging after about a minute. If I unplug and reconnect the charger, it resumes charging but only at a slow rate.
I would appreciate assistance in resolving this issue.
5 Comments
Cee-Ledge
01-20-2026 11:37 AM in
It could be that your cable is bad. Try using another cable, and also check that your charging port is clean
RudiFett
01-20-2026 11:41 AM in
Thanks, I have changed both the plug and cable to see if that's the problem. The same thing happened
MrChops10
01-22-2026 06:12 AM in
I am experiencing the same issue since the one UI8 update. It's a software bug. Charger the phone with a laptop or car
RudiFett
01-22-2026 06:15 AM in
Will give it a try thanks
CommunityTips
01-30-2026 09:15 AM in
You need to visit authorised smartphone repair shop to change the charging plate.
