S24 Ultra Heating and Battery Draining After Security Patch Update - S24 Ultra
(Topic created on: 03-21-2026 05:07 PM)
nasdique
Security patch level: February 5, 2026
S24 Ultra is getting heated up even while watching YouTube and along with it the battery is also getting drain faster. Require fixx...
4 Comments
Members_2Sb0gDr
Beginner Level 3
Same here. Not just me, saw this thread on reddit: Frequent overheating since Feb Patch : r/S24Ultra
Samsung_specialist
Thank you for sharing your feedback, and we apologize for the inconvenience.
After a security update, the device may temporarily heat up or consume more battery due to background optimization processes.
Kindly try the following:
  1. Restart the device
  2. Optimize device performance: Settings > Battery and device care > Optimize now
  3. Check battery usage for any apps consuming high power
  4. Ensure all apps are updated from Play Store and Galaxy Store
  5. Clear cache partition
If the issue continues after a few days of normal usage, please contact us for further assistance:
https://www.samsung.com/ae/support/contact/
nasdique
When samsung going to fix this through Update
Samsung_specialist
Thank you for your follow-up.
We understand your concern regarding the device heating and battery drain after the recent update and your question about when this will be resolved.
Kindly note that after software updates, devices may temporarily experience increased battery consumption and heating due to background optimization processes. This usually stabilizes after a few days of normal usage.
At the moment, there is no specific timeline available for a fix or additional update. However, Samsung continuously monitors such feedback and works on improvements through future software updates to enhance overall performance and stability.
We recommend continuing to monitor the device performance, and ensuring that all applications and system updates are up to date.
Your feedback has been noted and shared with the concerned team.
For further assistance, you may visit:
