S24 Ultra Camera does not follow settings
(Topic created on: 09-28-2024 11:18 AM)
akrammi
Hi guys,
I have noticed that while taking pics at 50MP, camera captures only at 37MB. Same goes for setting it at 12MP and it captures at 9MP.
Has anyone noticed?
Sharing photo for reference. See EXIF details. It was captured while setting it at 50MP.
6 Comments
Oozywriter
Did you try to change the resolution
akrammi
Try to change?
These defaults setting that camera has. I normally takes fotos @12MP. But pics are saved as 9MP. When I changed resolution to 50MP picture is saved with 37MP.
Try put 3:4. Don't 9:16, then see the result
Also, with 50MP put 3:4
Samsung_specialist
Using 3:4 will provide 50 MP.
akrammi
Thank you. 😊
@MOQBALI shared the solution and it worked.
Thank you again
