S24 Ultra Audio Distortion Issue
(Topic created on: 09-12-2024 08:05 PM)
ArunS24U
I am very disappointed with the last w update. Ever since installing it, the speaker in my earphones has been malfunctioning. This is incredibly frustrating, and I believe it's due to the update. Has anyone else experienced this? I would like to know if others are having similar issues. Why is samsung not resolving it, I have spent 130,000 on this piece of garbage I feel like filing legal case against Samsung
8 Comments
adit_mikku_
Hey, try reseting the Bluetooth and wifi connection > go to phone settings> search"reset wife and Bluetooth settings"> enter your phone pin> reset. STEP2- try restarting the device
ArunS24U
problem is with earpiece speaker not bluetooth or wifi
cs_member10
Dear Samsung Member,
Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
Clear Sound Alive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Alive> Storage> Clear data.
Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
You can reset your device by following the steps.
In case the issue still occurs, please visit the service centre for a physical inspection of your device. They will provide you with all the information in a better way after inspecting the device physically. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
ArunS24U
Got this step done through Smart Support but nothing has fixed. What next
Rohit1407
Hi can we connect facing similar issue on my S24
ArunS24U
Yeah, Sure
Rohit1407
On which platform we can connect ?
ArunS24U
do you have telegram or Insta
