S24 ULTRA battery drain!
(Topic created on: 06-15-2024 07:56 PM)
docshri
Hi, I recently upgraded to S24 Ultra from my previous s21+, and the battery is worse for s24 than my old phone; I don't know how to fix it. Is it the same with all of you? Central factor contact storage and Google Play services, is it because of WhatsApp dual messenger? But I cannot stay without dual WA; suggest solutions, thanks
5 Comments
Omar_Saleh
Also, my S24 ultra the battery drains fast.
MOQBALI
Expert Level 3
You need to modify the sitting to stop draining the battery. But if you play games, it will probably be draining. 🎮 #gaming #batterylife
laibah_59
According to his post, before the update, he was achieving 4-5 hours of screen-on time on his Galaxy S24 Ultra. After updating, however, he recorded eight hours of screen-on time with 26 percent battery still remaining.
laibah_59
Light Performance Profile. ...Auto Optimization. ...Adaptive Power Saving. ...Eye Comfort Shield. ...Do Not Disturb. ...Wi-Fi Optimization. ...Auto Dim. ...Battery Tracker.
docshri
Still battery drain issue not resolved, any working solution?
