hasinishrak
Beginner Level 3
07-01-2025 10:50 AM in
I just brought a s24 fe 8/256 variant. Although it has a 4700 mah battery im assuming it's performing like a 4000 mah one. How to increase battery backup can anyone recommend some tips.
2 Comments
TimonN
07-01-2025 07:21 PM in
There are multiple videos on YouTube about battery life improvement but following are some basics you can try.
1) Set Always on Display to show on tap , Disable unlock transition effects
2) Enable Adaptive Battery, Put unused apps to sleep from Settings > Battery
3) Set performances profile to light
4) In security, Disable fingerprint always on,show icon Set to tap to show, Disable show animations
5) Check if you have unnecessary apps installed and uninstall them.
hasinishrak
Beginner Level 3
07-01-2025 07:22 PM in
