Resolved! Solved
S24 Exynos Battery Drain
(Topic created on: 03-09-2024 07:48 PM)
arslmaqs
AoA!
Is 1% battery drain in 1 hour normal? While being on standby and phone not in use at all.
Exynos has performed very poorly btw should have gotten the Ultra.
mabdullah03
Bro watch this to solve your battery drain issue https://youtu.be/y5ewEJtT134?si=BEeJ8vnP-tnNWHsI
5 Comments
Or kia chahye bhai sahi hai
RANA_NAJAM
It's completely fine.
mabdullah03
arslmaqs
Great video!
arslmaqs
I am almost at 6 hours now.. will see how much it improves after this vid.1710228338124.jpg1710228338148.jpg
