S23 ultra update One ui 6.0 battery drain quickly
(Topic created on: 11-23-2023 05:21 PM)
Harman90
Hi everyone is there anyone facing problem in s23 ultra after update to one ui6.0. Im facing some battery drain very quickly. Internet stop working if mobile standby. Phone ringing but can't see the calls screen to answer call and phone start over heating.hope samsung will fix it soon.
6 Comments
I have s23 ultra but didn't face those issues
Harman90
You lucky
Harman90
See 5:20 fully charged and keep in my pocket and still battery drain but before ui6.0 was not like thisScreenshot_20231124_061559_Samsung Members.jpg
Try to use this code *#9900# press call.
Then, choose a low battery put if off put on, then exit. After that rest, mobile
This can refresh your battery and improve life
Samsung_specialist
Thank you for bringing to our attention the battery and network issues you're facing with your phone following the recent software update. To assist you in troubleshooting these issues, we recommend the following steps:
1. Reset Network Settings:
Navigate to "Settings" > "General" > "Reset" > "Reset Network Settings" on your device. Please be aware that executing this action will delete all network information, including Wi-Fi and Bluetooth settings. Exercise caution before proceeding.
2. Battery Consumption Issue:
We have compiled a set of steps that may help address battery consumption issues. Please refer to the following link for detailed instructions: https://www.samsung.com/ae/support/mobile-devices/what-to-do-if-the-battery-of-my-new-phone-seems-to...
Touseef14
Same issue have been facing and also phone is getting slow
