S23 ultra superfast charging not working
(Topic created on: 12-02-2023 06:49 PM)
BrandonM
My S23 doesn't charge at superfast speeds even with the 25w charger and the proper cable connect. Tried looking for a 45w charger for the superfast charging 2.0 and some didn't even charger the phone at all. And some only charge the phone only up to the 15w charging speeds.
I noticed that it sometimes charges at superfast speed sometimes today, mind you the phone is a week old. Does it need time to adjust or is there something wrong with it. Anyone else experiencing the same problem?
10 Comments
JstLykDt
25W fast charges the phone whereas 45W superfast charges. I stand to be corrected though
Tendai777
They are not original Samsung chargers. I had the same problem with my S21ULTRA. I used a 66w charger but it didn't super charge. When I bought a 27w Samsung charger it started super charging. That same 27w Samsung charger doesn't super charge my S23ULTRA. Maybe I will need a Samsung 45W charger
BrandonM
The charger that I'm currently using super fast charges my 20+ but not my s23 ultra, I tried other charges in store and they didn't trigger superfast charging
tmtdaonly
try checking if you turned on fast charger into your battery settings1701576717428.jpg
BrandonM
tmtdaonly
are you using the official Samsung charger or something different?
BrandonM
I'm using the official samsung charger, it works perfectly with my s20+
tmtdaonly
aish hey I'm sorry
try looking up more on YouTube or in the community or Google and see what you could to improve
Tomatoe
25W is just normal fast charging . If you want super fast charging, I suggest you get a 45W charger
