YASCER
4 weeks ago in
Can you please help me to sortout battery draining issue in s23ultra after one ui 7 update..
Did anyone facing same issues?
hamydansari
4 weeks ago in
What application is draining it?
YASCER
4 weeks ago in
If i enable mobile data or wifi started draining fast
hamydansari
4 weeks ago in
Must be applications that pounce on Internet the moment you enable. What happens if you keep the connection on continuously?
YASCER
4 weeks ago in
If i keep connection continously, drains very fast..
hamydansari
4 weeks ago in
If you can, try to reset your phone to factory reset. I know it is difficult but give it a try.
YASCER
4 weeks ago in
Thats the problem most of the datas in my phone very important... tuff situation
hamydansari
4 weeks ago in
You can back it up using Samsung Cloud. Data is something that you don't loose now a days. You've to be careful about the app data which are stored locally and not synced to cloud.
YASCER
4 weeks ago in
Exactly app datas very important am.worried for that only
Mahendran_27
4 weeks ago in
Yes! Even I'm facing the same issue! I thought it's just mine!
