10-10-2023 04:03 AM in
Galaxy S- Mark as New
10-10-2023 05:06 AM in
10-10-2023 05:11 AM in
10-10-2023 05:15 AM (Last edited 10-10-2023 05:16 AM ) in
10-10-2023 09:18 AM in
Galaxy SI have s23 and it heats up after using youtube for 10mins. I am also on september patch, not sure its my device or majority of the people facing it.
I am not liking this phone r
Because of the price I have paid.
UI is best but if phone heats, how will user use it.
10-10-2023 01:40 PM (Last edited 10-10-2023 01:41 PM ) in
Galaxy SSamsung really needs to work with their thermal issue..bcz sd 8+gen2 has very good in controlling thermals..
But don't know why Samsung is failing to optimisze with their s/w or any other thing..
See I am using s23+ a bigger phone,and with ufs 4.1..
Means it can dissipate the heat in a better way than s23,but it doesn't mean s23 should heat up highly. ..But still Samsung not able to resolve it..then it's a shame thing for them..
After paying 77k,66k for these phones,if we get this kind of issues..
Then what could we expect from other series.
10-10-2023 11:26 AM in
Galaxy S1. I turned off notification for some apps
2. I put some is sleeping, deep sleeping mode
3. I changed performance profile from standard to Light inside bettery settings
10-10-2023 01:46 PM in
Galaxy SIn my case I paid 15 to 20k extra for s23+..so what is the use..if I get this kind of issue..better to go for A series..it won't hurt us..bcz we are not paying this much..
10-10-2023 05:44 PM in
Galaxy SDear Samsung Member,
As per your query, kindly visit this mentioned link to resolve your device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
kindly visit this mentioned link to resolve your device battery draining issue: https://www.samsung.com/in/support/mobile-devices/what-to-do-if-the-battery-of-my-new-phone-seems-to...
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
10-10-2023 05:51 PM in
Galaxy SSo fix it by pushing an update to all the s23 and 23+ devices.
10-11-2023 08:12 PM in
