S23 Ultra camera/picture quality not good
(Topic created on: 07-21-2023 09:28 PM)
AmandaM
Hi Everyone
I recently upgraded and got the S23 Ultra, before I had the S20 plus. The picture quality of the camera images is not good at all. The pictures are a bit blurry and not really clear/bright. I'm having to remaster the pictures everytime to make them look better, which is not what I expected with this phone. My S20 plus took way better pictures. I'm up to date with the updates. I've resetted the camera settings. Not sure what else I should? Is anyone else having the same problem with their S23 Ultra? Please help. 🙏🏽
8 Comments
LeonSteyn
Didn't you get the recent June security patch with about 2.2GB size update? That is a massive camera fix. But yes, the S23 does have blur issues. Disappointing cause otherwise it is such a great phone.
AmandaM
I'm up to date with software updates. Very very disappointing! 😞
zangoune
zangoune
Reamejeannick@gmail.com
tumi2004
I use s20 fe and even I don't face those issues, try disabling the 200mp mode if that doesn't work go into settings app click apps then search for the camera app in there and clear it's data there after do the same for the gallery app if that doesn't work then idk
AmandaM
Thank you, will give it a try. 🙏🏽
Tani25
Beginner Level 4
I'm having the same issues despite being up to date with the updates. Very frustrating
AmandaM
Very frustrating and disappointing :-(, especially when you look at the value of this phone. I was really expecting the best when I bought it.
