S23 Ultra Battery
(Topic created on: 02-23-2023 08:32 AM)
Given10
It's been 6 days using the S23 Ultra. I feel like my battery drains fast.
15 Comments
Given10
You get what I'm feeling, I can't worry about battery issues with such an expensive device 😔
outcast1
My guy you must know that your S23 ultra has a verry high display refresh rate at 120hz and a lot of pixels on display as well with high resolution so obviously the battery will drain verry fast.What you need to do is set you your refresh rate to 60hz in settings it will save battery and set your display to full hd+ not quad hd+ if your device is already on all these settings know that your phone is still new and learning your usage patterns.
RejoiceTmof
Can we talk z fold3 5G 💔💔💔💔
Damjam
I feel you shouldn't have to turn down your refresh rate to 60Hz. You spent money to have an awesome device, enjoy it.
What you should possibly do that won't really affect anything you can see, but still give you some improvements is below.
1) Turn on light performance mode (more battery settings/performance profile) This stops the CPU from being at full speed in day to day use. It doesnt apply when playing games so you will still get max performance on that. You won't even notice a difference. I did a benchmark on full speed and at light performance and it reduces it by about 10%, but the scores are still higher than almost all other phones lol.
2) For apps that you don't maybe need running all the time, put them to sleep or even deep sleep. This will obviously affect notifications so don't go putting your whatsapp/email etc to sleep if you need your messages. But those games that give you notification reminders to play them, probably put them to sleep.
Enjoy your QHD 120Hz goodness and keep your battery lasting long too
MAN WHAT DO I DO??😭😭😭MY PHONE IS LITERALLY LOSING BATTERY % LITERALLY EVERY 3-4 MINUTES. This is so not cool. I've tried everything but it won't stop dying fast. I need help.
Sachm
I had a similar issue, put the phone off and check if it loses considerable battery life, mine did that and Samsung exchanged the phone for me
