S23 Ultra Battery
(Topic created on: 02-23-2023 08:32 AM)
GeeScorpio
It's been 6 days using the S23 Ultra. I feel like my battery drains fast.
15 Comments
Miraulder
If you go to Settings > Battery and Device Care > Battery > Click on graph > what does it show as using the most amount of Battery?
Perhaps there is an app that's running that you aren't using
GeeScorpio
Miraulder
🤔 maybe it's just the device learning your usage patterns. My S23 Ultra felt like it was lasting longer in the first 2 days, then after it learnt my usage patterns it also felt like it was a bit worse, but they recommend 2 weeks for the device to properly optimise
GeeScorpio
That's what I was advised 2 weeks max.
Miraulder
Let's hope so
Did you do the update to the latest software?
GeeScorpio
Not yet, but I will.
Miraulder
Let's cross fingers and hope it's better. Although I can definitely say the S23 Ultra is still better than my S22 Ultra, hands down!
DakaloR
Same here 😢
Now it's always on battery saver
Miraulder
My S22 Ultra used to sit on Power Saving mode always 🙈
Felt horrible having such an expensive phone on Power Saving Mode
