S23 FE Battery Drain Issue – 5-6% Overnight Without Usage
(Topic created on: 02-11-2025 03:09 PM)
sidh3369
I recently got the Galaxy S23 FE, and I’ve noticed that the battery drains 5-6% overnight even when the phone is idle with no usage.
  • No background apps running
  • Always-on display is off
  • Adaptive battery is enabled
Is anyone else facing this issue? Any suggestions to fix it?
Let me know if you want me to modify it further! 😊
11 Comments
sidh3369
Battery drain every night, and with flight mode on, it drains 3%.
For reference, my old Mi Note 6 Pro drains 0% even after 6 years.
yatran
3 to 4% same conditions
sidh3369
which phone
Babru
What phone are you using now?
sidh3369
S23fe
Babru
Exynos has always had a problem, can't help but see you suffer 😊
Babru
Happens on all the phone, soo chill 😂
sidh3369
5% is much drain,
my other samsung worth of 15k didnt drain this much,
so how can i chill,
goodthings
Your's device is new so please give it some time. After some time and After some updates all is well. So please don't bothered about this issue now. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
