S23+ Battery Issue
(Topic created on: 02-18-2024 11:26 AM)
ADaas
After February 2024 updates for Samsung Galaxy S23+ it started Battery draining faster compared to previously without updates. Anyone facing the issue with Battery Draining.
4 Comments
sms222000
Try this maybe help you
Wipe cache partition by booting device into recovery mode. It should solve your problem.
Samsung_specialist
Here are some steps you can take to troubleshoot and potentially resolve the battery draining problem:
1. Check Battery Usage: Go to Settings > Battery > Battery Usage to see which apps or processes are consuming the most battery. This can help you identify any specific apps or services that may be causing the drain.
2. Close Background Apps: Close any unnecessary apps running in the background, as they can consume battery power even when you're not actively using them. You can do this by swiping away apps from the recent apps screen or using the task manager.
3. Restart Your Device: Sometimes, a simple restart can help resolve software issues that may be causing battery draining. Restart your device to see if it improves battery life.
4. Update Apps: Make sure all your apps are up to date. Developers often release updates to optimize their apps for the latest software versions and address any bugs that may cause battery drain.
5. Reset Settings: If the issue persists, you can try resetting your device's settings to their default values. Go to Settings > General Management > Reset > Reset Settings. Keep in mind that this will reset your device's settings but won't delete any personal data.
