S22 update problem
(Topic created on: 05-13-2024 08:21 PM)
kannyB
Is this me or you guys are also not able to download it?
17 Comments
techness
Same not able to download
Rk9114
Is there any bug in this update?
Jay702
No bug detected
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly check your device network once and make sure your device is properly connected to the internet connection to download the latest software version.
Kindly follow the below steps to update your device software( if available).
Path: Settings-> About phone-> software update
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
kannyB
Just accept it that it was Samsung's server fault
mackchavan
bro upgrade to 5g network bro don't use 2g bro
kannyB
Using this site from windows explorer on windows 98? Dumb f c k doesn't even know what servers are and what date i posted this
