S22 ultra hang/touch problem
(Topic created on: 10-09-2022 07:33 AM)
Saki123
Dear All
While using my s22 ultra its screen automatically gets held, stops working. Until i off the screen and then on it, it doesnt work. First i have to off the screen by pressing power button and then i on it, then it starts working. this is so annoying. Pls help to resolve this. Thanks
8 Comments
Saadi121
Yes it's after September security patch
Saki123
I am facing it since i bought from april . Seems to be built in fault
Saadi121
Then complain
Saadi121
I also face this
Saadi121
Kindly report Samsung here
Saki123
Any solution to that, they said to reset device by resetting all settings. Will this work. Any one tried this?
Saadi121
And replace it
kakaayub
Update waiting April problem solved 💯
