S22 ultra charging problem
(Topic created on: 01-08-2025 10:11 PM)
ngute
After i updated to new software now my phone has issues with charging is anyone facing same issues
3 Comments
Hello possible or go to Samsung maintenance will definitely help you 👍 I advise you to go to Samsung maintenance and not a normal phone center if your question is answered correctly please click on three points above and click on The solution has been accepted and thank you for your question 👏
Samsung_specialist
We apologize for this issue , please try thaese steps :
Check your charger
Run a test using Samsung Members
Clean the charging port
Check for water and moisture
Reboot your device
Update your software
Check for damage
Try a wireless charger or wireless Powershare
Run your phone in safe mode
you can refer to this link for more detalis : https://www.samsung.com/ae/support/mobile-devices/what-to-do-if-your-galaxy-phone-is-not-charging/
If these steps did not work please visit the nearest service center for more inspection https://www.samsung.com/ae/support/service-center/
Beginner Level 3
Shahwali Dawar Zai @gmail.com
