S22 ultra battery
(Topic created on: 06-08-2022 01:20 PM)
Burki
S22 ultra had a great battery life, but for the past one month I feel it is draining fast, is it something you have observed
6 Comments
coolater07
Go to setting and go to device and care you can check which apps is Working in the background
Burki
I frequently use device care
Hi it takes whole 2 weeks to get it optimised as your device is learning your usage than you will get the best battery life. Do note if you get OS updates in between than it will take 2 weeks after the update to get it optimised.
Burki
That makes sense, I had the June update, let me monitor
Samsung_specialist
Hi,
For assistance, please visit one of our authorized Service Centers to check it for you. You may refer to the link it will guide you to the nearest service center to your location https://www.samsung.com/ae/support/service-center/
coolater07
In the device Care you will find what your apps drain your battery faster maybe bcoz it working in the background or you can put your apps to sleep. Or otherwise, go nearest service center
