S22 Ultra video recording problem
(Topic created on: 04-24-2022 04:05 AM)
Elurdo
Beginner Level 3
Sometimes when recording a video on room light and a stand flash light, or moving from a room to room, the video starts flickering to adjust to the room light or to the object that moved in front of the camera, this affects my recording as I'm a video creator, and makes my videos look bad because it catches the light flickering effect.
However this doesn't happen if I enable auto FPS option, but I don't want to use the auto FPS because I want my videos to look smooth in 60 fps.
I record with UHD 60fps.
I never faced this problem with my S20 Ultra.
I would attach a video to show the problem but I don't know how.
6 Comments
I've observed these when lighting changes drastically. Also, there are issues when you zoom and lens changes. Feels like frame is lost.
Elurdo
Beginner Level 3
When lighting changes or a new object enters the frame 🤔
And true about the zoom too
Shutter speed doesn't change immediately when the lighting conditions changes
Hi Elurdo, thanks for sharing this post.
I experienced the same In the low light situations so what I m doing now is to use the Pro mode that does not show the flicker and this flickering issue might get resolved in the next Android update.
You could try to disable the AutoFPS feature sometimes that also solves the problem.
Or you could click a bright spot on your scene and lock the slider by holding on the driver until it gets yellow as this might too get rid off the flicker.
Looking forward seeing your videos out of the S22 Ultra.
nicknameinuse
I got an S20 Ultra. I'm getting screen flickering in slow motion and super slow motion camera modes. Changing the lighting or trying to focus didn't help.
Samsung_specialist
Hi,
For assistance, please visit one of our authorized Service Centers to check it for you. You may refer to the link which will guide you to the nearest service center to your location https://www.samsung.com/ae/support/service-center/
