06-04-2022 07:36 PM (Last edited 06-04-2022 08:19 PM ) in
Galaxy S- Mark as New
06-04-2022 07:42 PM in
Galaxy SAlso try once using powersaving mode
06-04-2022 07:46 PM (Last edited 06-04-2022 07:47 PM ) in
Galaxy SP.S: My S20+ used to charge alot faster with the same 25 watt samsung in-box charger (0-100% within 50 minutes)
06-04-2022 07:55 PM in
06-04-2022 07:56 PM in
Galaxy SAs with 85% limit, you may have enabled it under Battery Settings.
06-04-2022 08:02 PM in
Galaxy SAs for 85% limit NO. I have checked it alot of times and Protect battery is not enabled. Thanks for your concern however, I've already clearly mentioned it in the post for Samsung. If they ever see this post and care about their community.
06-04-2022 07:53 PM in
Galaxy SLINKS in the following post can be helpful:
https://r2.community.samsung.com/t5/Tech-Talk/Smartphone-Basics/td-p/11180153
06-04-2022 08:03 PM in
06-04-2022 08:11 PM in
06-04-2022 08:17 PM (Last edited 06-04-2022 08:19 PM ) in
Galaxy SThe experience with S10+ and S20+ was just bad due to exynos and its idle battery drain. However, this time with Snapdragon its no different to be honest.
Also, the fact I want to prove here is Samsung needs to improve stability of updates. It's just bad specially in terms of battery and charging performance.
My phone used to charge just fine when I unboxed it with the version that came in the box, it was march or april update maybe.
