S22 Plus Battery draining too fast
(Topic created on: 04-22-2022 02:44 PM)
SamAwaden
My new S22's battery is draining too fast.
i have to charge the phone at least 2 times a day, if not 3.
i connected support twice and got nothing useful.
is this just me or is this a common issue with S22 plus?
15 Comments
Hi, what is the screen on time?
SamAwaden
about 6 hours
I believe 6 hrs of SOT is normal for an S22+.
SamAwaden
i used to get a lot more from my Huawei with a smaller battery 🤷
How long you've been using it now? Usually a new device should take 2 to 3 week to be optimized. 🙈
SamAwaden
they told me 14 days.. it's been a month and I'm still very frustrated with the battery performance ☹️
Try putting individual apps to restricted mode in battery usage and try turning on adaptive battery in battery settings
SamAwaden
you don't buy a new top of the line phone to keep your apps on sleep and use battery saver mode, do you?
I personally use it for my S22 Ultra cause of convenience, I only put my unused apps to sleep and set adaptive power mode. The S22+ should typically go good with 7 hours on average so these are suggestions I have given to make the most of your device.
