uw3r
03-11-2022 01:56 PM in
I used xiaomi original power bank to charge my phone a couple of times... then the phone started showing moisture detection sign, upon checking I found out to only use original charger...now with the original charger my phone has stopped fast charging and for some reason the charger charges in only one direction and doesn't charge if I twist the charger and plug in again... need help to resolve without opening my phone
3 Comments
eyeshabutt
03-11-2022 06:22 PM in
Hair dryer sa cool mode on krky ap 2 mint charging port ko air do
im_naved
03-11-2022 08:34 PM in
Use sunlight heat to remove moisture before 2 days its happened with my device
innovativeAR121
03-11-2022 08:42 PM in
Clean your charging port with makeup software brush and give air
