S21 ultra exynos battery time & overheating
(Topic created on: 02-16-2021 11:06 AM)
Moizshahid
I'm getting terrible screen on time with my phone set at wqhd resolution. 4-5 hours SOT at max. Also, phone is getting warmer than usual. Is anyone else experiencing the same issues? Any work around to fix battery issues?
12 Comments
New update is rolling out to fix the battery drain
IsmailAkram
I am also using at QHD+ and for me battery is great, as great as I had on iPhone 12 Pro Max. what you doing that overheats your phone?
Moizshahid
Normal usage, taking a couple of pictures results in phone overheating in a bit. Have you updated the phone to latest software, seems as if there have been an issue because of February security update
Moizshahid
Mind sharing your SOT or if possible a screenshot of battery usage.
IsmailAkram
here you go, it's unplugged for ,21 hrs
Moizshahid
Pretty nice, what's your software version AUB3 or AUB6
IsmailAkram
AUB3
Moizshahid
Great for you then, it's bound to get better with AUB6 update
IsmailAkram
yea but I won't be able to play pubg at extreme settings 😜
