S21 ultra battery saving tips
(Topic created on: 02-05-2021 10:14 PM)
GalaxyGuruSA
The 21 works differently due to android 11 with battery saving, off course yoy can keep it simple and use the preset modes,or get even better results, thst involves a lot of tinkering. First up, put it in battery savings mode,then go switch display to hd+ thereafter go to data saving and enable it and then go in further and only swith apps on to go through the data saver whith you need to get notifications from. You csn also go in individual apps and disable background activity manually. Also get a book type  cover to keep the phone from waking up unnecessarily in your sgirt pocket,whenever the light  sensor detects light or movement.  Close open apps occasionally. Stay on a wifi connection as far as possible, antennas for cellular reception uses more battery. Also try to avoid using the second sim, when its non essential. There you are,share your thoughts in the comments!
2 Comments
umaryesuf
Help
GalaxyGuruSA
With,what?
