S21 FE overnight battery drain **bleep**
(Topic created on: 12-20-2022 06:35 AM)
PKsamsung
Without turning on Bluetooth, Wifi, Mobile data, location overnight, My S21 FE battery drain is about 4-6 percent in night. Even i use phone on dark mode eye confort shield extra dim in night. After one ui 5 I have reset my phone also but. Its happening after one ui 5.
In one ui 4, overnight ideal battery drain was 2 percent only.
After one ui 5 , battery drainage issue not solved even more battery draining whole day I have to charge 3 times a day with SOT 4-4.5 hours.
4 Comments
piyussh07
I charge twice in a day, Sot ranges from 4 to 4:30hrs, but overnight drain is 1%
Have you put app to sleeping & deep sleep?
Akshvani
I too had a same issue of battery drainage in night with only mobile signals on & no apps on background
GoggleMaharaj
switch off the phone at night...will drain only 3% 😂...serious battery issues with this series...seems Exynos is more efficient than developers
sita021
Beginner Level 3
Only way that worked for me is to turn the airplane mode and nothing else.
Before i would lose like 4% or 5%. With airplane mode, I don't lose even 1%.
Good question is should you turn it overnight? For me it's crucial to stay on so yeah.. It **bleep**.
I wonder will Samsung start to take care of their consumers. Battery is terrible, no AOD animations.. Probably the last Samsung phone I'll buy.
