07-14-2022 11:26 PM (Last edited 07-14-2022 11:26 PM ) in
Galaxy S- Mark as New
07-15-2022 12:43 AM (Last edited 07-15-2022 12:47 AM ) in
Galaxy SGo to Settings > Connections > Sim card manager. Then turn off and turn on the sim and hopefully that should solve it.
From the Settings > Connections > Mobile Network, Make sure 5G is turned on.
07-15-2022 02:32 AM in
08-22-2022 03:22 PM in
Galaxy SIMS registration status not registered.
Let's fix this the same way I did for myself,
Take out your sim card from the phone,
Now you need another android phone to do this.
Don't use Samsung devices. In this case, I used my old Lenovo,
Insert the sim card to another phone then go for Sim Management.
Click sim card info then put your sim card number manually,
With following country code like this +966XXXXXXXXX
Keep turn on the mobile data for 3/4 minutes if you see 4G/5G/VoLTE,
Then plug out the sim card and insert it into your Samsung device.
Now your IMS registration status get registered and your phone will,
Start showing 5G, VoLTE and WiFi calling features.
