S20FE 5g Camera FPS Issue & poor quality
(Topic created on: 12-19-2022 01:54 AM)
Mukulbhar
Video shooted at 30fps but due to frame drop it's showing 26fps
Video shooted at 60fps but due to frame drop it's showing 28fps
Frame drop to 23fps while shooting at 30fps
Since August 2022 I am using samsung 20fe 5g and i am video creator/YouTuber I have been using iphones and lot of samsung mobile before for shooting vlogs/videos
Since I started using Samsung S20fe 5g i am facing a issue where I record any video with 60fps 4k telephoto lens or 30fps 4k ultrawide lens with HEVC or without HEVC format i could see the frame drop issue and video jiterring which is really annoying. Also after updating to Android 13 it's makes camera quality degraded.
I have attached some video samples and screenshots where you can see fps showing for shooted video even though 60fps videos stored in internal storage and my phone has a lot of storage left to be used (more than 20gb) but still this issue happens 7/10 times and for 30fps videos in ultrawide lens I have selected Samsung EVO plus 130mbps sd card but still result is same even I choose internal storage for 30fps video.
If samsung doesn't care about highend mobiles like S20fe 5g which is a successor for samsung then it's really Shamefull.
Samsung should work on camera quality and functionality for A and S series phones because if someone is investing 30k+ for a mobile for video and camera quality then money should be justified.
I have more than hundred of videos which has frame drop issue and wanished my work. Also If i select HDR10 for video then situation becomes worst. Really samsung doesn't care about their mobile phones which ment for camera and video purpose.
14 Comments
Saif007_
My s20 fe don't have such issue. Is it after updating to oneui 5?
Bibhu987
You've 5g variant or 4g variant ️when did u buy it
Saif007_
5G
Bibhu987
Bro requesting u pls help me. Pls upload or send a video at 4k@60fps. Pls bro do it and lemme know if there're minor frame drops or not
Saif007_
4k60fps, video size is big and i use mobile data so can't upload but there is no frame drop. Screenshot_20221219-131103_Gallery.jpg
Bibhu987
Bro pls go to samsung video open the video there select go to editor then from editor select size and format then select hevc videos size will be reduced then pls send 😢😢
Saif007_
Not able to post video here, for some reason its greyed out 🤨
Bibhu987
Ok😔😔😢
Bibhu987
Yes bro it's happening with some units not with all.you can visit my profile I also mentioned that
