S20 ultra battery problem
(Topic created on: 08-30-2023 10:26 PM)
Ahmedzaki95
Any one have same issue?
16 Comments
DG_AUH
How can u check this?
Ahmedzaki95
Samsung members - support - dignostics - battery check
Please do it then tell me what you find
AH1AK
No, mine is fine.
Take you phone to the nearest Samsung store or service centre.
Ahmedzaki95
Good
No need, still working well ❤️
Ahmedzaki95
What is type of your phone and when you bought it?
AH1AK
S23 ultra. Bought it on Feb 2023
Ahmedzaki95
Wow good
Still have time
I hope it will be great for a long time
Samsung_specialist
Hello,
Kindly make sure that you are using the original charger, please try to diagnose the battery from the settings > battery and device care > battery. Otherwise, you should visit the service center.
P0PC0RN
Make sure you have a good and not damaged charger.
