S20 battery issue
(Topic created on: 03-08-2020 09:04 PM)
AmnGill
Hi,
Is anybody facing battery drain issue with s20. After 100% charge,  battery dropped to 96%  within few minutes without any usage and keeps on draining .  Quite a concern. Also AccuBattery is showing 3505mah battery capacity against designed capacity of 4000mah. Has anybody checked battery capacity with AccuBattery for s20/S20+?
19 Comments
SamratGhose
let your phone learn your usage pattern. it will settle down within 12-14 days. by the time enjoy your purchase
AmnGill
Thanks bro
s4s
No need worry about accubattery showing less capacity. After few days of use, it will show it correctly. Its common with all new devices of any model. Regarding drain, no idea as I don't own s20
AmnGill
Thanks
Aashish
Expert Level 4
That's normal bro.
AmnGill
ok
abhi2700835
Battery will learn up your usage and use power saving mode if you are not on gaming this will close unnecessary background processes and sensor only and save alot battery
_007
Expert Level 4
Do few more charge cycles.And then check Accubattery app.
AmnGill
ok
