ManjuPrasad
05-22-2020 02:40 PM in
Hi, I bought S20 plus few days back, the issue is I am not getting any incoming calls from anyone.. but I can make calls, receiving sms, can use mobile data etc. How can I sort out this issue, if any one knows please advice
3 Comments
MohammedSijah
05-23-2020 08:02 AM in
Galaxy SHow did you notice the problem? What it says to the caller during the call?
ManjuPrasad
05-23-2020 08:27 AM in
I tried to call from another number to my S20 plus, then I came to know that calls are not connecting even the mobile was switched on. I can hear that " the person is not available " or "mobile switched off "
MohammedSijah
05-24-2020 12:16 PM in
I think this is an issue to be reported to your service provider. I have seen some S20 users posting similar complaints. Any way switching to 3g may solve your issue temporarily.
Goto settings>connections>mobile networks>Network mode.
Select 3g only.
Thank you.
Select 3g only.
Thank you.
