S20 Fe Battery Draning
(Topic created on: 10-28-2022 09:47 PM)
Gowthamkichuz
Any Ones Samsung S20 Fe 5G Battery Draning Problem????
7 Comments
sreesankar8
Yes, I have,but i don't know the situation right now, i changed to 21fe, where there is the same problem
Gowthamkichuz
Okay
Kuldipindia
yes little battery drain issue than before. but still good for whole day it is giving backup. end of the day i have to charge.
Gowthamkichuz
Ok bro
Oldbird_1536
Yes , i am also fasing same issue , battery draining so fast also issue with network carrier .
sreesankar8
S20 fe is now ok with my wife's phone after software update.it's not draining in night times.
Now S21 fe has to become ok
cs_member8
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
