01-19-2022 02:13 PM in
Galaxy SHello, did anyone see improvements to battery life of exynos 990 or have we just been scammed? Can I return this phone in warranty? Its 5 months old.
I'm still getting 3.5 hours of SOT max with every function like 120hz , always on etc off, I don't use any power draining apps, nor play any games. Set my phone to factory default and still no change.
Anyways, what is the reason to have 120hz, always on display or high performance, when I can never use these functions for battery life? Thats a scam ...
01-19-2022 02:50 PM in
Galaxy S- Mark as New
01-19-2022 05:17 PM in
Galaxy SDon't get me wrong I like it, but with the battery its unusable. It's like having a 5 year old phone. Actulally my old S5 with Lineage OS lasts like a week on idle 😄
01-19-2022 05:20 PM in
01-19-2022 05:27 PM in
Galaxy SDude you're nice :) But I'm an IT guy, and I really barely use the phone, no fb or anything just Whatsapp and teams ... Tutorials won't do any good, wish it was that easy 😄
And yeah the reviews always show like 7 hours SOT vs 8 on snap. It's just a scam
With my redmi note 8 pro I did not need to turn off all apps on background or any functions. So why does Samsung treat theirs consumers worse ? Just weird
01-19-2022 05:41 PM in
01-19-2022 03:40 PM in
01-19-2022 03:41 PM in
01-19-2022 05:12 PM in
Galaxy SIt's real sad, I changed from my beloved Xiaomi note 8 Pro which did like 8hours even after 2 years. Now I have barelly usable, twice as expensive phone. I checked like thousand of blogs of weird solutions where none worked.
The last one I see is to break my warranty, root the phone and disable Mongoose M5 cores.
I really start to understand the iPhone users who just don't have to care about this.
01-29-2022 09:15 PM in
Galaxy SDear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
