S20 FE Heating, Battery issue Solved
(Topic created on: 05-09-2021 01:22 AM)
Nhronju
Samsung S20 FE 4G Exynos Overheating and Battery Drain issue is solved after changing some settings.
 I've changed these settings 1 weeks ago, and after using 1 week,
 I've never seen Overheating isseu. And Battery Backup almost 8 hours by browsing, FB, YT etc.
So Im surely thinking that this is software issue, not hardware. I hope Samsung fix the issue by software updates.
Ok let's talk what settings I've changed?
Turn off GPS, Bluetooth, NFC, and others unused service.
Turn Off All auto Sync,
Turn Off Digital Wellbeing,
Turn Off Find my Device.
Uninstall unused Apps,
Turn Off Google Sync,
Disable Bixby and other Unused app,
Turn of unused gesture, Use Dark Mode, Display screen timeout 15 sec,
Inside Battery settings,
Add unused apps to deep sleep, Block all unused app notifications,
Turn Off Edge panel, accident touch, touch sensitivity.
Turn Off Always on Display.
But I've used 120 GHz all days, Trust me, I've never face the issue throughout the week.
Thanks
17 Comments
TECH_MAN
How to turn off find my device
🤣🤣😆 then what is the use of device if all settings needs to off ? Dusre company ka device me aisa to nehi hota ...practically hangsung device day by day turned into worst after every software update because their software is never optimized+ exynos
Exynos chips are like that. It won't change. Try to get a sd version if u r planning to buy some other phone
Not applicable
This is bad. Shouldn't happen in the first place. No chipset is this bad. Exynos is the only reason I wasn't interested in Samsung devices earlier. But in the end got S10 lite last February and I am still happy after a year now. No problems whatsoever. Hope you guys get a resolution asap.
DeeS22UltRa
If these settings should be turned off then why to buy 40k+ device better go with below 10k😂😂
Rickee
Switch off tha phone. Why you bought. Exynos worst chipset. Heating issue never bi solved.
Raysleek
Beginner Level 3
I'm very disappointed with samsung, I have sent several mails to them about this. SAMSUNG WE CANTBUSE PUT S20FE TO DO BASIC TASKS. HELP US FIX THIS OR RECALL YOUR PHONES OR GIVE US A REFUND. WE CANT USE OUR PHONE FOR 10 MINUTES WITHOUT IT HEATING UP LIKE ITS IN A MICROWAVE. we don't even know of this has an effect on our health. I use my previous Samsung A70 for streaming even while charging for 6 hours and the temp is normal. On s20fe a phone with 6 gig ram, I can't use Samsung Internet for 5 minutes without the phone burning up. I am from Nigeria and the weather here is pretty hot also. Sometimes I have to place my phone on ice to stream videos. What is all this
Raysleek
Beginner Level 3
Samsung we can't use our s20fe it always heats up so bad and closes all apps. Please we can't use our phones. Since day 1. Sort this thing out or replace our phones or refund us.
