(S20+) Battery Problem
(Topic created on: 12-17-2020 12:35 AM)
Anshulj98
(s20+) Battery🔋 draining so fast even after one ui 3 update.. i have to charge 100% twice a day for regular use. Battery performance is very poor 😕
Kindly suggest If there is anything which can help.
3 Comments
Not applicable
flash last firmware from Samsung service center which is process to install any big ui interface
cs-member13
Expert Level 4
Dear Samsung Member,
We are sorry for the inconvenience caused to you. We request you to kindly send us the error log file along with the Video or Screen-shots within 15 minutes of issue occurrence through error report section from Samsung Member Application:- Samsung member > Click on beta banner > Switch to beta mode > Beta feedback > Send feedback > Error report. As this will help us to further investigate and resolve your concern.
Anshulj98
nothing is helpful tried many methods ... kindly share some solid solutions
