Highlighted
Beginner Level 3
I am facing tremendous amount of battery drain issues with my S10e. I am on July update currently.
--On Android 9 November update, my SOT was 5 hours 30 mins average with 12+ hours of stand by time
Below are some steps that I performed to limit the battery drain, but these helped very little
1. Wipe cache partition
2. Go to each app's  info -->
  i. Mobile Data --> disable - Allow background data usage
  ii. Battery --> disable -Allow background activity
3. Disabled chrome, because it hogs on resources & battery
4. Disabled - Auto Sync Data
5. Disable/Uninstall social media apps
6. Used sleeping & Deep sleeping apps.
7. Always on Dark mode.
After these steps, I hardly reach SOT of 3 hours & 25 mins with 8 hours of stand by time (approx)
Please HELP!
8 Comments
Highlighted
according to battery capacity of 3100 mAh
sot should reach atleast 6-7 hours if you are not a haaard core gamer
Highlighted
All mobile faced battery drain issue wait for next update and also send feedback to samsung
Highlighted
now I can only suggest you to visit service centre and get reinstall your software update
or once you can check after factory data reset
Highlighted
bro it's a Samsung thing. I am a Galaxy user since s5 and I know after every update they make your phone slow and battery life is less .You can't do anything but wait for software update . give your feedback it can be resolved by software update only . Even you have paid 50k + for your phone it is budget phone in Samsung's eyes. they only think about current devices.
Highlighted
I disabled a lot of bloatware through minimal adb. It worked
Highlighted
Battery draining is problem for every new Samsung phone. Because of its ONE UI.
Every One UI phone has BIG Battery but still can't give single day backup.
Highlighted
Highlighted
Dear Samsung Member,
We apologies for your inconvenience. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
