S10e Battery Drain Issue
(Topic created on: 02-24-2022 11:53 PM)
lippi02
Hi guys,
Since Android 12 came in my S10e jumped from 4,5-5,5 hours of screentime to 2,5 hours, max 3.
Anyone have any working solution to solve this issue?
I usually use my phone in battery saving mode, and turn of everything that I don't use (like NFC, Bluetooth, Auto Sync., Always On Display, etc.), but these get me to the mentioned screentime
4 Comments
rap1021
Its happening across all S10 series after updating to Android 12.
Manish189
It frustrating, facing the same issue..
Manish189
I just solved this issue.. downgraded first to android 11 December patch using firmware complete install.. then again installed Android 12 through OTA. Now my S10e is giving me 16 hours easily with 6 hours screen on time.
lippi02
Can you share us a little tutorial how you did it?
