Highlighted
Beginner Level 4
After August 2020 security update battery drain is drastic on my s10 plus ..now i am getting very less screen on time ..please samsung do something waiting for your good response ...#s10+
#battery #batterybackup #galaxy s10 plus ......
4 Comments
Highlighted
wait for next update
but till then check did you do these settings
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
3. Google >click on 3dot>usage and diagnostics >off this option
4. Long press on each app specially 3rd party(LIKE FACEBOOK, INSTA,YOUTUBE) and rarely used and ON "GOOGLE APP" as well then click on>app info> then go to these 3 options below on by one
5. Device care>battery >select "optimised and adaptive power saving.
Highlighted
Follow these steps to get best out of your phone battery.
https://r2.community.samsung.com/t5/Tech-Talk/Battery-saving-tips/td-p/2920797
Currently I am getting 6.5 hrs SOT and idle time going almost 1.5 - 2 days in my S10+
Highlighted
you mentioned in ur link about adding Google Play services to deep sleep. There is no way we can do that since it's a system app. August patch has pathetic standby even after deep sleeping almost all apps.
Highlighted
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
