rp16
10-23-2019 09:28 PM in
The battery life seems to be improved after September update. Hopefully doesnt degrade after android 10 update.
Easily getting upto 6 hrs daily on qhd+ resolution
2 Comments
sudipta90
10-23-2019 10:21 PM in
can you share some tips? i get 3 hrs SOT with a single sim and 15 hrs in wifi.
rp16
10-23-2019 11:15 PM in
use adaptive power saving and delete or stop background activity of apps you hardly use. Nothing much and use dark mode it does help a bit .
